electric choke connector
    does anyone know where i can get a pigtail for the electric choke on an 85 vic, mine looks like its about to break, thanks
    Junkyard would be my first thought. Likely any CFI motor from that era would work (Ford, Lincoln, Mercury).
    If you can post a pic of the pigtail connector you need I'll take a look and see if I have a spare here somewhere.
      If it's the single wire connector... you may be able to use the 3g alternator stator wire harness. https://lmr.com/item/LRS-14290C/94-0...ng-Stator-Plug
        no junkyards near me have boxes, and the single wire connector i need is round and plugs into this : https://www.rockauto.com/en/catalog/...+/+heater,6004
        sorry no pics of my own
          oh... that bastard. I think you can swap it out for the flat blade version which I think is the CV232 or CV231. The complete listing is shown in model year 1979 on Rock Auto. Then you can use a standard flat blade connector harness.
