2 Row aluminum Radiator?
    for the upper hose you can just order a rad hose for an 85 Vic with a 351. The upper hose is 1 1/4, the later cars with the plastic tank radiators were 1 1/2.
    That is exactly what I did. I am going to cut it to put in the e-fan temperature probe coupling. Lower hose I will figure out. Then when/if that is all done, I will figure out how to get the '04 CV radiator shroud/cover to fit over all of that.
    I forgot that Brown Muscle already installed his; actually remember reading that post too :-/
