im new to the site, shit im new to a 5.0 but im learning and building. where should i start with my car? what would be the recommended place to start on my car, i was thinkn the exuast and the intake. any tip will help this rook over here. if anyone got some good tips pleas let me know.
88 vic stock 302
Welcome, mang!
Just remember what I told you about exhaust earlier
Find a set of stang shorties and an Offroad H pipe, and run your muffs with dumps (turndowns)
Then, consider the HO conversion or even an engine swap...
I'm sure the guru's will be sure to pipe in here in a minute...1983 Grand Marquis 2Dr Sedan "Mercules"
start with dual exhaust and gears........these are the biggest bang for the buck.
and welcome to gmn!
scott
Exhaust, exhaust, exhaust. Biggest gains for a stock vic. 2.25 all the way back with some stang headers and h-pipe. Impala tails work great for the over the axle part.Builder/Owner of Badass Panther Wagons
Yes, welcome!
I have some stock Mustang headers/manifolds I can send you for your exhaust system, if that's what you want to do. I didn't pay for them, so I won't expect you to... just cover the shipping.
If you're interested, let me know. I think they'll even fit in place of your stock manifolds, if you want to go ahead and do them. Worth the $10-15 for shipping, in my opinion.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Welcome!! This place has helped me soo much I need to donate some $$$! Once you do the gears and the exhaust, try an HO conversion. I'm in the middle of one now. Getting to the cam is a bitch but other than that pretty straightforward.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
and for all of the above, yup. I'll also toss into this standard maintainence items, tuneup, fuel/air filter, etc.86 Lincoln Town Car (Galactica).
