this sucks
    this sucks
    as I got my passenger side header off today, I noticed one of the head bolts was missing its head....I was able to get the cylinder head off, but now i have an inch and a half or so of a bolt stuck in the block, with no threads on it. Any ideas on extracting this thing? Ill put a pic up asap
    Its a whore but you need to drill into the bolt and use an extractor. Sorry, no easy way out here.
      If theres some bolt sticking out of the bloxk you might be able to use vise grips.
      1989 Grand Marquis LS
        Vise grips or a small pipe wrench will likely do it. If you have 1" of bolt sticking out you should be able to grab it. Soak it down with some penetrating oil for a day or so before messing with it. Buy all new head bolts, perhaps something a bit better than stock. Seems the stock bolts aren't so hot. The 86 TC XXX has is getting the engine yanked for the same reason. I really wish I'd put upgraded head bolts in my engine when I rebuilt it, but it was simply something I never considered at the time. If I had it to do over again, it would have new bolts tho.
          yea i'm gonna use new head bolts from now on too......does it look like this mang?
            Yea Scott, thats exactly what it looks like, and looks like the same exact location too. hmm maybe there is some design flaw
              heres a picture of the bolt that broke off
              Are My pistons supposed to look like that, i mean completely flat-topped? My Lincoln is an 89'
                thats what mine looked like
                  what ever you do ... you need to make your avatar smaller
                  it takes up half the damn page.
                    I've had to fix a broken head bolt on a 302 as well. You will probobly need a helicoil if it's stuck. It was a bitch and a half to fix. But took no more than 2 hours working slowly.
                      Aww hell, you have plenty to work with there. I was under the impression that it might have snapped off flush with the deck surface. PB blaster and a little torch will loosten that thing up. Soak, heat, soak heat....... Do like blaze said and work slow and steady.
