EGR cooler line delete?
    Still trying to track down a coolant leak from rear of engine... working theory is EGR cooling.
    Can I just delete the T from the heater hose and then plug the smaller hose to the EGR?
    It is pretty cramped on the backside between firewall and motor, so I can't tell where the return line goes after the EGR -- just back to the manifold?
    (FWIW, I tried searching a few times here first but no luck tonight -- just get the "waiting" server message and no results).
    Thanks!
    yes you can delete it. i think they meant it to leak in 25 yrs and make a mess.
      The line goes into a small fitting thats close to the back drivers side corner of the intake.
      Because of it's size, location and the junk back there, it is hard to see and even harder to get at.
      I've done it two or three times now on different cars, it wasn't any fun and very frustrating.
      But it can be done.
        Oh good!
        Suggestions or options?
          what is the purpose of the stupid cooler lines running through the throttle body?
          -1973 Volkswagen Bus Westy
          -1986 Honda Magna 700cc
          -2011 Subaru Outback
            If you want to fix it, you can see the fitting from the drivers side with a flashlight.
            Just follow the hose down to the back of the intake, the fitting is about 2" behind the last fuel injector on that side.
            I would remove the bracket that holds the trottle cable/TV cable and set it aside with the cables still attached.
            And disconnect the two wiring plugs you can get at and the AIC, they run infront of the fitting you're trying to get to.
            Once thats done you should be able to clearly see the fitting, especially if you move the wiring out of the way.
            A long screw driver or quarter inch socket, with a swivel and extension should get it.
            Or you can just remove the fitting and replace it with a plug.
            This is on a 91CV, if you have a metal/coolant tube running down the pass. side of the intake.
            And the EGR coolant line starts there, nothing I said applies!
              Throttle body icing. If you are old enough, just like carb icing, when the temperature and humidity are just right ice can build up during steady state highway driving jamming the throttle blades in whatever position they where in while cruising.
              Alex.
                I've measured about a 10F increase in air temp at the sensor with the lines connected vs disconnected. I've never had it run dumb in the winter but I rarely drive it in extreme cold either.
                  Thanks... maybe a bit easier for me and the '85 w/ CFI. Any idea what plug I would need so I could get it in advance?
                  Also, what is "AIC"?
                    I'm guessing he means IAC, which is something you don't have on an 85.
                    For what its worth, the EGR cooler does not function as a throttle heater on an 85. There are actually passages in the intake for that, the ones that the EgR actually feeds through. That flappy thing in the exhaust forces gas through that to stop "carb" icing.
                      So unless you live in Extreme temps, there really is no need for this spacer, as it will leak and without a it, the engine will run cooler, he he who would've thought of that
                        If I daily drove the car, and actually went any sort of distance i'd be tempted to try plumbing it in with a bypass to see if there was any change in fuel economy. In theory, less dense hotter air should go with less fuel, and might very slightly improve fuel mileage. Or maybe it wouldn't do a damn thing, don't know. Impossible to say without testing, but since I drive the car so rarely I can't actually do it.
                          [QUOTE=gadget73;745126]I'm guessing he means IAC, which is something you don't have on an 85.
                          You're right, I ment the IAC, serves me right for not checking back on what I wrote.
                          If the engine uses the intake fitting I have no idea what size that is, but it's small.
                          Just have to pull it and match it up to the right plug.
                            1/4" NPT i think.
                              no loss I could find when I bypassed it.
