Ok so there's a short pipe that come up from the exhaust manifold on the drivers side... It looks like there's something that should go between there and the cold air intake bottom.... Am I right or what the hell is it for..... Anyone got pics of what it looks like in place and what the part number is... Thanks.
What is the part I need...... 1985 cfi lincoln.
"stove pipe"
I don't remember the technical term for it though. you can use steel/HD aluminum flex hose cut to length for that.
Yeah, you should be able to find universal stuff on the shelf at a good parts store. If you ask someone to find it for you though, they probably wont know what you are talking about!
Its definitely not a critical part, all it does is divert warm air from (the exterior of) the manifold to your air cleaner for cold warm-ups.
Although, some states that have Nazi emission inspections will fail you if that is missing.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
