Hello all! Sadly, this is my first time back in some time, and sadly to ask for much needed help. My '79 LTD base model 302ci will not start. I am a professional automotive technician by trade, so this has been extremely frustrating on such a simple system. The vehicle started hard on a rainy night once after what I first thought was the starter grinding on the flex plate. Upon examination under the hood, I found this noise to be electrical popping/arching in the starter solenoid.This was after the car was shut off and would no restart. Since this point in time, I have loaded the parts cannon, replacing the starter solenoid, starter, solenoid-to-starter cable, negative battery cable, and charging/load testing the battery which is in decent health, holding 12.47 volts. I have cleaned/sanded and applied dielectric compound to every connector or connection I have touched. I have triangulated grounds by running dedicated grounds from the starter solenoid housing (where it mounts to the inner fender) to battery ground, as well as from the starter case (lower mounting hole) to battery ground. My problem is that I now don't even have the popping/arching noise from the solenoid. I now turn the key to the run position to see brightly illuminated engine and amperage lamps in the dash (normal) and turn the key to start to hear the solenoid click, but nothing else happens. when I let go of the key, the lights are very dim and the solenoid will not click again. However, if I turn the ignition off and back on again, everything is bright and happy again. Further diagnosis has found battery voltage present between the input and output polls of the starter solenoid when the ignition is off. If the solenoid-to-starter cable is disconnected, there is no continuity found. I have also found ground present on the solenoid-to-starter cable. This cable is brand new (I fabricated the damn thing myself, hammer crimped and soldered, connections covered in heat shrink tubing) and not in contact with ANYTHING other than the positive starter connection and the starter solenoid. To make matters worse, there is now a SECOND new starter and starter solenoid in the vehicle with the same thing happening. I thought there was a chance I might have overtightened the positive input to the starter, causing the connector to make internal contact with the case, thus causing the ground I was reading on the solenoid-to-starter cable. WTF IS GOING ON HERE!? Any thoughts or ideas are most appreciated.
Tricky No-Start Condition!
All the required Fuseable Links good??? Any other shorts????
where's the 12.47v? car off?sigpic
Originally posted by miamibob View PostAll the required Fuseable Links good??? Any other shorts????
Originally posted by 1990LTD View Postwhere's the 12.47v? car off?
do i have this right?
- battery voltage at starter side of fender relay with key off
- battery voltage at starter side of relay disappears with cable to the starter disconnected
I now turn the key to the run position to see brightly illuminated engine and amperage lamps in the dash (normal) and turn the key to start to hear the solenoid click, but nothing else happens. when I let go of the key, the lights are very dim and the solenoid will not click again. However, if I turn the ignition off and back on again, everything is bright and happy again. .sigpic
I thought about ignition switch concerns, but I honestly don't know how to properly diagnose them. I just dont understand how you can have battery voltage going through the solenoid while it is supposedly off and not have the starter turning over/ wires burning up. And yes, you have it correct.
since the lights go dim after you turn the key to start, I'd guess the battery to solenoid cable is shot. When you put a load on it, it goes high resistance. They are often green and fuzzy inside. Give it a bend, if it crunches, its shot.
The battery voltage on the starter side of the solenoid with the starter not hooked up is probably feedback through the ignition switch. If the key was on when you checked it, thats not entirely impossible. The ignition system powers from the I terminal on the relay when the engine is cranking. When its not cranking, with modern digital voltmeters that present essentially no load, you can get a bit of leakage back through the diode and have it read voltage. Put any sort of load on there, and it should drop to zero volts.86 Lincoln Town Car (Galactica).
whats your volatage while your trying to crank it over? im thinking that you have a dead cell in the battery. if your soleniod is clicking while your trying to start i think to me thats a dead cell along with the lights going dim. even though the battery is showing 12 volts but thats without a load on it correct? hope this helps. matt1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbines
my bad i just read that you load tested the battery already1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
Originally posted by gadget73 View Postsince the lights go dim after you turn the key to start, I'd guess the battery to solenoid cable is shot. When you put a load on it, it goes high resistance. They are often green and fuzzy inside. Give it a bend, if it crunches, its shot.
What happens if you jump the solenoid?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Well, the car starts and runs just fine. However, I'm still rather befudled. After finding continuity between the positive connection and case ground on my SECOND rebuilt chipanese taiwan garbage starter (one from napa and one from o'reily), I returned it and replaced it with a brand new unit from autozone of all places. The car started right up. I'd say there are some quality control issues going on, that would be the first and very hopefully the last time I have two back-to-back defective components... THANK YOU EVERYONE FOR YOUR INPUT AND IDEAS! I know I can always count on you guys, what a great community.
