The DREADED KNOCK part 2...HO block installed
    Is there a difference between an HO and LOPO Throttle Position Sensor (TPS) ?
    What exactly doe the TPS control and do?
    Thank you,
    M
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
      Oh-- you've left the lopo upper intake and throttle body on also?
      So, what's HO in it anyway then, just the block?
      If you've got an HO cam, then you need an HO upper intake, HO throttle body and egr spacer (minor machining required), HO injectors, HO ecm.
      I think we told you all of that ;-)
      But if you've left it lopo, that's fine, so long as they put your lopo cam into the ho block!
      The blocks are virtually identical; the heads are a little better on the HO, and the pistons are flat top for slightly higher compression.
      Shifting problems could all be attributed to the tv cable. See what the actual trans shop can do.
        DREADED KNOCK # 2.5.. Hopefully part #3 will be the finale! On the POSITIVE SIDE!
        Hello Good Weekend to ALL,
        I drove the kids to the park andto the Academy Store. Time to buy roller skates and got suckered into kid size golf clubs. For girls. cheap 7.99 each set of 3 24.00.
        The car drove as I had been saying. I was able to pay more attention and play with the coloum shifter. Had the same results but it seems like I start off in 2 and has a 2-3 shift at 25-35 MPH possibly plus 10 MPH speedodmeter error. The 3-4 shift occurs at 45-55 MPH, again plus 10 MPH speedometer error. I figured this out when i took off from a dead start and pulled the shifter down to L and it downshifted. Apparently it is starting in 2nd gear. Playing between Od and D on the shifter has no effect and does not up shift or downshift. The trans downshifts on its own when stopping from 3-2 normally. It seems if I drive at low throttle the shift is HARD. If I drive at Hard throttle the shift is MILDER. Hmmm? If while apparently in 4th I floor it it does not kickdown at all. Same thing when it apparenty is in 3rd, no downshift into 2nd
        I bet it is the LOPO ECM trying to find the correct shift points? This is a question.
        Thats all...Another IPA is calling.
        I know its been listed before but does anyone know what the correct Normal shift points (2.75 rear) for BOTH an 89 HO AOD and a 91 LOPO AOD in MPH and RPMS ....PLEASE.?
        Difference in parts in a stock HO AOD and a stock LOPO AOD transmission? adjustable Governor? stall speed converter?
        Thank you ALL again,
        Mike
        Keep my education going please.
          The AOD is entirely mechanical/hydraulically controlled. No ECM worrying about shift points....in the early days of the aero Panthers they switched to the AOD-E. E for electronic.
          I don't know the difference between HO and regular AOD transmissions, but I think it's all in the governor.
            The ECM has nothing to do with the shift points. The trans isn't electronically controlled. The only thing that makes it do it's thing is the TV cable setting.
            Only difference in the transmission is the governer in the tailshaft. WOT with an HO is about 4800 rpm, WOT with a lopo is about 4200. Outside of that, same stuff.
            Shift points really vary based on how you drive it. The Ford process talks about using a pressure gauge and a spacer block to adjust the cable. I never do that, I just mess with it till it feels right. In manual D, WOT at 50 should downshift to second gear, WOT at 55 should not. If you get the cable so it does that, its pretty close.
              Your transmission is not connected to the ecm in any way.
              Go dual exhaust, you will not lose power at any point.
              All mustangs had headers, though poor flowing compared to aftermarket.
