Just changed plugs - question on getting more room.
    Originally posted by P72Ford View Post
    I have all the emissions crap on my '90 351 car.
    And none of the emissions stuff on my '87 302 car.
    Its much nicer without it.
    Also... I'd love to see pictures of your Impala.
    Did you make those things running along the heads over the plug wires, or can you buy em?
      Upgrade the air box. Go to the junkyard, get an airbox from a 1990, 91 TownCar or any other panther from 92+ Get the air box, install it on your fender. Get a fanshroud from a '90 TownCar, and a washer bottle from a '90 towncar or later panther. Get an air intake tube from a '98+ non towncar and plug the holes. Problem solved. And what's nice is that those air boxes use the same air filters as the stock box on the 5.0 panthers.
      I got the airbox and washer bottle. It's a little rusty around the four bolt holes that hold the square housing to the air box "outlet". (That is/was probably the MAF sensor?). Do you take that thing off? It has a hole in it anyway that would need plugged on mine. Also guessing you leave in that sensor thing that sits beside the MAF. Next time I go will have to look for the air intake tube. I'm betting that 1990 fan shroud from a Lincoln TC is like trying to find hen's teeth.
      95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
      96 Buick Roadmaster Limited Wagon, mostly stock
      77 Ford F150, 400M auto, longbed
      98 Suburban LS 5.7L Vortec, stock
      90 Grand Marquis, stock
