302 EGR System
    302 EGR System
    Ive got my 81 LTD running pretty good now, but the EGR is not hooked up at all. I have diagrams, but trying to figure out what is what is really not working out for me. I know that a vacuum line is supposed to be running from the EGR to some vacuum switch on the intake, I believe. Not sure which one, cause there is 3 of them, and not one of them has vacuum lines hooked up to it. Could someone please give me a basic run-down on how to hook mine up?
    YOU CAN NEVER HAVE ENOUGH RUBBER!!Just too much sheet metal!
    -1969 Nissan Patrol(5.2L/NP435/NP208/D44HD/D60FF)
    -1981 Ford LTD(5.0L/AOD/8.8)
    -2001 Ford Escape(2.0L/M5)
    Facebook
    honestly, if its running well without it, I'd leave it that way. If its been disabled for a lot of years, the passages are probably packed up with carbon, and it will either not really work, or a chunk of carbon may stick in the valve and make the car run bad.
      Will it not have a negative effect on my fuel mileage? I'm aiming for 18mpg on a 65mph trip.
      Facebook
        on a carb model, not really. The EFI cars will lean out the fuel mix when the egr valve opens. A carb can't do that.
          on a traditional carbed application it'll probably reduce part throttle detonation and make a pretty significant emissions difference, but that's about it.
            Thank you. That helps me out alot!
            Facebook
