87 TC 5.0 running rough
    I've been working on this thing for quite awhile now. I finally got it to run but now it has a stammer when accerlerating. It's kind of hard to describe. It idles smooth but when the throttle is pressed the motor vibrates. It's not a loose motor mount I know for sure and it does this hot or cold. Here is a list done to it so far.
    New PIP
    New TPS
    New MAP
    NEW plugs and wires
    New ignition module
    New coil
    Timing set
    I'm at a loss here. I was thinking maybe a bad O2 sensor causing on side to running different then the other?? I'm not sure it works like that. Any ideas?
    Jeremy
    Does it do it in neutral?
      Oh good question. I do believe it does. It don't really get worse. basically stays the same even when accelerating. Just a little more pronounced I guess.
        Make sure, cause we might be looking at possible transmission problems.
          It does this in neutral as well.
            ever run a code scan, particularly a cylinder balance test? Also, have you verified that the firing order is correct? I've seen cases where someone mixed up a plug wire and it runs basically ok at idle, but has a distinct miss and vibration at above-idle speeds.
              I'd triple-check the firing order on the cap.
              Counterclockwise.
                ALSO! Verify that cylinder #1's spark plug wire is on the '1' marked on the distributor cap! They do weird things if it's not right.
                  Haven't run codes on this yet. I was fighting yhis dam car last year before it got too cold out. Al I got then was a TPS low output and thermactor code. Last year I couldn't even get it to run more then a few seconds. Then just a few days ago I tried firing it up after it sitting since last november and it fired and ran. The dam thing is a mystery to me right now. We did work heavily in the distributor area. We fought timing as my dad decided to pull the distributor and jacked up the timing. I will double check the firing order. Thanks
                  jeremy
