You don't need to use the little elbow that comes with the PCV valve, do you? I don't see why you would but I thought I'd ask you guys given the fact that I can wire a distributor backwards and not notice.
stupid PCV question
stupid PCV question
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
to clarify:
not on your SEFI engine. that elbo is intended for the older carbed and CFI engines that have the PCV valve it the rocker cover oil cap.
I figured it was for the valve cover type breather - thanks man!sigpic
no worries young blood! lol
we can just cap off the second hole?
I did my pcv valve over the summer, but actually now I can't remember what I did... hope it's not been blowing oil all this time
What did another poster mean by the "pcv trifecta"? It's just that one valve, right? Or are there two other components to address?
The generic ones you get from Fram at Wal-Mart have the elbow.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Last one I used had the elbow as part of the valve, couldn't remove it. I can't remember what brand it was though.sigpic
yeah the 95 has the same one in the valve coversigpic
i kinda thought the screen should always be replaced as well...1985 Mercury Grand Marquis ls-302 CFI
Carb swap planned .
c90 heads
475 lift cam
Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
Built aod(want c6 tryin to fin vac mod model)
331 stroker kit
Work in progress
