Idle
    Idle
    I tried at the other place and didn't get much. My car quits when I turn on the A/C. The idle will not rise and the car quits if I don't give it some gas. It only does it at idle and when I come to a stop. Any ideas from this side?
    clean that IAC!!!!
      :stupid:
      If cleaning does no good, replace it. Its the small motor looking deal on the rear side of the throttle body. Two small bolts and it comes off.
        Isn't there some kind of solenoid or something that engauges when the copressor engages, or is that only with the CFI cars?
          Thats the CFI Blaze
          The Best
            Ok, I though so I jus remembered it from dealing with this on your car.
            IAC valve is where it's at man. I had to replace mine a while back and it was fairly new. When they go bad they through a lot of the perfomance off.
              Thanks. I'll replace the IAC.
