fuel tank leak
    fuel tank leak
    I have a small leak at my fuel tank..... again. A while back I replaced the gasket and locking ring at the plate where the fuel pump installs. Although it's hard to see, i think it may be leaking again in that same spot.
    The lines are dry where the hoses connect.
    Does anyone sell that plate assembly?
    yes if you look at rock auto, you can get the whole pump assembly complete with lines and wiring
