Towing Capability
    Towing Capability
    For lack of a better place to post this:
    Any one know the tow specs of an 85 Mercury Colony Park?
    What would you recomend for upgrades?
    I am looking to tow about 3000 pounds. 200 tongue weight.
    Are there any boxes with heavier springs than the wagon has?
    2000 Grand Marquis LS
    Mercury Owners Group member
    I towed an 86 Towncar with my Towncar. We figured about 4700 lbs all told with the dolly and the car. It did OK except for a hill or so on the last part of the trip. Going uphill at 35 mph with the pedal down isn;t so fun. 3000 lbs shouldn't be much of a problem. My Towncar is rated to tow 3500 lbs according to the manual, and I'm guessing your wagon should be rated similar.
    Cargo coils for a wagon are going to be the stiffest you can get most likely. Since your springs are almost new, I'd probably just install a set of air shocks to level the car. Adding a transmission cooler is an excellent idea and will keep that AOD happy. An engine temp guage is also a must.
      I agree.
      A shift improver kit prob wouldnt hurt either...
        Originally posted by Grand_Marquis_GT
        I agree.
        Do they sell one for the AOD?
          yeah, a mild shift kit would be a good idea. It reduces the time spent between gears, so the clutches are partially engaged for a shorter period of time, thus reducing wear and heat. Also on the list of stuff I wish to do with my car.
            I towed an 86 Towncar with my Towncar. .
            Thanks
            very good advice.
            I found in my Brochure that the CP can tow 5000 with 3.55 gears and coolers. So I should be able to 2500 with 3.08 and coolers.
              I got a trans-go kit sitting in my backseat
                Can't imagine it would do much good there!!
                  Oh come on. You mean you cant feel the power over there?
                    I'd probably think about swapping in a 3.55 anyway if you're up for it, but you should be OK. Just take it easy and stay out of overdrive on a stock transmission. The OD band is a weak point and it will burn up if you abuse it too much.
                      Oh, there, I feel it now. Oh wait that was the Mexican I had for lunch.
                      :banana:
                        I only ever use OD on the highway over 50 anyways and towing I would never use it at all. I don't like the way it feels when it trys to downshift from OD when at low speeds.
                          lol...
                              It is not doing you a whole lot of godd there now is it?
