ok heres one for you
    ok im a decent panther tech,but im not too sure what to make of this one. I got a messge on one of the boards im a member of,actually citruspeed is from that board too lol anyway heres the questions i got
    I need some ideas in order to fix my problem. I have a 1988 Lincoln LSC 5.0 HO engine. I have installed it into an early Ford Bronco. The problem that I have is that it pops through the intake under acceleration for about the 1st quarter mile. Then you feel a surge of power and the popping stops and the engine runs amazing. When you come to a stop and idle for a while when accelerating again the popping may return but not always. Once again in about a quarter mile it is gone. Please help! 1-888-269-3969
    What is he using, the efi stuff or a carb?
    It almost sounds like a carb loading up on fuel or a timing issue.
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
      Agreed.
        i had the same problem with my 67 four door. it was the timing/wires on the wrong plugs.
        i fixed it when i wised up, rearranged the sparkplug wires and timed it correctly all in a city wide blackout.
        my
        67 Ltd tudor
        67 Ltd 4door
        85 Ltd 4door
          Without specifics on exactly what he's using, it could be a lot of things. I could rattle off EFI crap but that won't help if he's running a carb. It could be as simple as a crossed or defective plug wire.
            lean condition or not enough ignition/timing
