Fuel problems
    Fuel problems
    I just spent money on a fuel pump and strainer with the labor of dropping the tank to find out that the tank was like brand new as was the fuel pump. After a lot of time and money spent, I finally ran a test on the car (86 Grand Marquis) and got the codes 11 (koeo) and 12,21,41,91 (koer). I see that one is for the ECT which I'll just change, but does it look like the other 3 codes point to the fuel pressure regulator? It almost had the symptoms of a weak fuel pump, like slowing itself down while driving but it starts instantly all the time and never dies out at idle. It has been using a lot of gas too.
    "It is the soldier, who salutes the flag, who serves under the flag, and whose coffin is draped by the flag, who allows the protester to burn the flag."
    -Father Dennis O'Brien, USMC
    it might be the regulator if you gots codes and it starts fine. the engine wont have a demand for fuel, only when you get on the throttle that the engine needs the fuel demand and a faulty regulator will hold back that demand which means drive ability issues. ever put a fuel pressure gauge on it?
      I never put a pressure gauge on it. The guy that works on it just poked the pressure valve with a knife and threw his head out of the way. The fuel came spraying out very quickly. That's the first thing that made him think it wasn't the fuel pump, but I was never able to test the pressure under a load. One of the codes said it can't hold steady RPM's under heavy throttle or something to that effect and the others said it ran lean on both sides.
        you could also have a blown injector or more. I especially think that might be the case since it's gulping gas more than usual. sounds like it's flooding out. Could also be the metering valve if it's just letting the fuel run through unchecked. The trouble codes point out that the oxygen sensors are reading lean. If you did this with the engine warmed up already, this would indicate that you may have sensor issues, but since you have code 21, either the coolant temp sensor is bad, the wires from it are bad, the connectors are corroded, or the engine wasn't warm, let us know if it was warmed up when you took those codes. If it's warm already and still has those codes, you may have more issues than you think.
          The car was warmed up for 2 minutes, that's what the scanner said to do. We did this test on 2 different occasions to make sure they had the same results. I forgot to mention that while I was messing around with the car trying to get it to run better, probably a month ago, I unhooked the vacuum line from the regulator and drove it about 5 miles, it didn't slow itself down once.
            in that case, it may be the vacuum switch going to the regulator. It may be allowing full vacuum all the time (if I understand the system right). Your regulator may be fine, but the controlling vacuum may be "hosed" so to speak.
              There is vacuum going to the regulator but I don't know how much is too much or too little. I might just try a new regulator and go from there.
                if there's nothing on the line between the regulator and the manifold or vacuum tree, then it's probably the spring in the regulator. I don't remember the vacuum setup on that one so I can't say for sure. Does sound like the part to swap though.
                  The vacuum line on the regulator has manifold vacuum. When the engine has low vacuum, so should the fuel pressure regulator. Pressure should be higher without vacuum. Oh and the knife opening the schrader valve on the fuel rail? Not a valid test. Throw a gauge on there and let us know what you find.
                    did you replace the fuel filter?
                      ya, the filter can give you crazy issues too
