Carb Question...
    Carb Question...
    Just a general question here...
    I have a small inline electric fuel pump that provides gas at 5 psi to a small bore Rochester 2 Jet.
    I have the pump running, and the carb off the intake (don't want fuel running down in the engine). If I open the throttle there is a nice steady stream of gas for a few seconds... and then it stops. Shouldn't the stream continue as long as I have the throttle open?
    If I close the throttle, and then re-open it, I get the stream again, and then it stops.
    Same deal with part throttle, just a smaller stream.
    Is that right? Or is there some other issue?
    This seems to be a noob question, I know. Its just that it would seem to me that the fuel flow should be continuous at WOT.
    That stream is the accl pump and is working right. There shouldn't be gas continually out vacuum sucking it out.
    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
      Yep, what he said. All you're seeing is the accelerator pump shot.
        yeah, accel pump action.If you had fuel running steady down the carb, there would be something wrong with it.
          Good, good.
          Thanks guys.
            Remove the needle from the needle-and-seat; that'll ensure a steady stream of fuel running somewhere .....
              This thread makes me wonder what mechanical fuel injection looks like up close.
              If you ever get fuel running down and it's not the accel pump, check your float bowls. I had one extremely miscalibrated out of the box on my Eddy 1406.
                A high-pressure pump that feeds fuel to each injector though a separate line, the injectors are spring-loaded inside so the needles don't move until the line pressure gets high enough. If you link up the throttle lever of the high-pressure pump with the throttle body butter flies you can maintain your air-fuel ratio, throw in an aneroid somewhere on the pump too so it can account for heavy-load low-vacuum conditions... Simple in theory, I'd imagine it's a bitch to calibrate every thing tho.
