Radiator cap after you just went around 90 mph for 20 min??
I ask because I recently changed the thermostat '195', radiator, an hoses an filling it up an checking for leaks (found none). Now when I drive the coolant temp Gauge stays before the 'N' .
Now After I drove fast for 20 min I pulled over and wanted to see if I had pressure in the cooling system. I squeezed the upper and lower radiator hoses. I could squeeze them both very easily, I unscrewed the radiator cap an nothing gushed out. the coolant looked calm an peachy.
Is the system not pressurized?
Could this mean my water pump is shot?
Some added info:
NO water in the tranny lines
No water in the oil
Heater core appears normal, no puddles or smells
Upper intake feels hot, Radiator feels warm.
Fan clutch works aswell as fan
Thanks fellas for any helpful advice.
Some added info:
No water in the oil
