draining oil?
    draining oil?
    I needed what I thought was about a quart, but now it's very slightly above the full mark. I should have added it in smaller amounts than I did. Do I drain a tiny bit?
    Don't worry about it, you'll lose more than the extra that you put in if you try to drain it.
      dont worry about it.
        cool, figured as much. How much excess would be a problem?
          When it starts coming out all of your seals, you know it's a problem.
            main issue is you dont want the crank to be submerged after overfilling, but you'll be fine
            1989 Grand Marquis GS
