My power steering pump has just started leaking, along with my electrical problems. I have such good luck. Anyway I think its leaking out the front shaft that the pulley attaches to. Then getting on the pulley and slinging fluid everywhere. So can I just buy a replacement pump or am I gonna need to hit the junkyard.
Power steering pump leaking
You can get replacement pumps. You have to swap the pulley over usually, its a press fit but you can use a strong bolt and nut as the press, if you had a puller to get it off with. Your local discount auto store might have a rental kit to do this with.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
