Pre oiler pressure question.
    I have a 5.0 actually a 302. Had some lifter noise and the engine quit. I had it towed home. Oil pressure indicator lamp is out. I removed the oil pressure and temp put a oil pressure gauge on it and removed the dist. I used a 1/2 drill with a pre oiler shaft. I do get oil pressure, just not sure what pressure ball park I would see. Anyone else tried this before.
    at cold idle as long as its over 55-60 i wouldnt be worried. as for what it would be with a drill it all depends on what type of drill your using and how much power and speed it has.
