Igniton module fell off!
    Thursday, on the way to work, my car died on me, first time it has ever left me stranded. I called my supervisor, since he works part time at a paint and body shop. He went and got their wrecker, and picked me and the car up, then took me to work. He got their mechanic to work on the car, while i was at work. Turned out that the two bolts that hold the electronic module on the side of the distributor had coroded in two... and the module basically "unplugged" itself from the ditributor and was laying on the intake manifold! The bolt was coroded because of the dis-similer metals, aluminum housing, steel bolts... So we used some of the dis-similer metal paste that electricians use on aluminum to copper connections, to keep this from happening again. What is funny is, I was going to change the module out this weekend, as it had a crack in it. So since he couldn't get what was left of the bolts out of the distributor... Without drilling it out and retapping it, etc... He replaced it. He said there was also a fair amount of play in the old one, so it was probably best to replace it anyway. It was probably the original. I called my old Advance Auto Parts store I used to work at, and the manager sent their parts truck to another store to pick the part up, and delivered it to the shop for me, and let me pay for the part after work.
    Helps to have friends! (She has always been super helpful, and knows her stuff when it comes to parts.. She has her own race car)
    So, since the change out, the car is running smoother than it ever has... It also has quit having all of the "issues" it has been having... We figure it has probably not been "grounded" well for some time. Here is a list of what it was doing, So if you are having some of these problems... you may want to check to make sure your module is grounded to the distributor...
    1. BAD spark knock... Even after going to the cooler thermostat like the Ford dealer suggested... Not as often, but it was still doing it once and a while when starting out from a stop light.
    2. Smoking really bad after idling more than about 5 minutes... It would blow blue smoke and rattle really bad until the smoke cleared up... Usually after about half a block... then it was fine.
    3. Sometimes when you started it up, (After the initial warm up, like stopping to eat somewhere) it would start up, then quit, then when you restarted it, is would run fine.
    Yesterday I was off from work, and the car is running like a new car. I let it idle for twenty minutes while I worked on some radio issues with the new console I will be putting in it... And it ran fine when I drove off... no smoking, no spark knock... It runs like new!
    Nice, and the problem was easy to find. Damn thing flew off on you. Good to hear that is has solved your problems.
      Hmmm. I wouldn't have figured that the blue smoke was an ignition problem.
      Glad you got it fixed though.
      GS
      Axle codes
      Open/Lock/Ratio #
      G / H / 2.26
      B / C / 2.47
      8 / M / 2.73
      7 / - / 3.07
      Y / Z / 3.08
      4 / D / 3.42
      F / R / 3.45
      5 / E / 3.27
      6 / W / 3.73
      2 / K / 3.55
      A / - / 3.63
      J / - / 3.85
        Probably it was getting weak spark, and not burning off the oil seeping past the valve seals. With hotter spark it might be burning this off properly. You may see a slight increase in fuel economy now too.
          Good to hear! I'll keep those symtoms in mind next time someone has the same issues.
            So far the car is running good.. and it did help with the gas milage... won't know for sure until I check the milage at the end of this tank to see how much, but I can tell by how far I have gone so far, versus how much fuel is still in the tank.. that it is better.
            Next project, putting the new tilt steering column in the 84!
              Hey Tom,
              I'm off tomorrow and Tue if you need a hand with the 84.
              1991 LTD P72 351 W Restored Century Police (Ongoing Project) Sergeant Vic.
              It's a dog eat dog world and I'm wearing milk bone underwear.
                Another trick to prevent this I picked up in the military working on helicopters is to paint your screw or bolt threads with zinc chromate (if you can still get it) or cold galvanizing spray. The zinc also acts as a lubricant to keep the threads from seizing.
                One thing you shouldn't do is replace the screws with stainless steel. This reverses the galvanic corrosion and causes the aluminum to corrode, pretty quick too.
                  must be that salt air......it is rare that i see the module screws rot off
                    No, it is called disimiler metals. If you bolt aluminum and steel together, they will oxidize. The make a product called "No-lox" that is a paste that you put on the screws before you install them, and it will not do that... We put the stuff on the new bolts... But of course, the distributor is original... so it only took 18 years for the bolts to corode in two!
                    The "No-lox" is made for electrical connections, when they put aluminum wire, and copper terminals together to keep if from oxidizing... My Dad was an electrician for years... So I still had some!
                      Its dissimilar metals, but the salt in the humid air accelerates it quite a bit. It works as an electrolyte. And yes, stainless and aluminum together rots the aluminum. It happens on marine drives, especially ones that aren't properly protected with sacrificial anodes.
                        Just checked my milage on my car since the new ignition.... 74 miles driven, used 3.82 gallons of gas... (And I really packed" the gas tank...) For a grand total of 19.3 MPG!!! that is a mix of interstate (66 miles) And in town driving (8 miles)...
