more work done....
    more work done....
    I got the mounts for the cage done today.. hopefully I can get the two remaining parts of the cage spotwelded tommorow... My welder has been really busy lately on projects away from his shop... So I have to catch him when I can... Then I can bolt everything in the car.... and get the rest of the trim in.
    The hole is for the seatbelt bolt to go thru... which will mount the cage mount to the "B" pillar....
    The second hole...^^
    is for a second bolt I figured I could install to make it stronger... There is a trim screw hole there... So I am going to drill it out a little bit, then put a 5/16 thread cutting bolt in...
    reminder of what the cage looks like...
    After the cage.. on to wiring all the equipment! Tom...
    Awesome, you do some great work man. Atleast from what I can see online. Keep up the good work! :slug:
    -Jeff-
    My CarDomain Page
    2002 P74
    Arizona Beige
    20% Tints All Around
    Tinted Tailights
    Clear Corners
    Sound System
    Leather Interior
      work
      Thanks!
      Hopefully I will be able to get it installed tommorow.. then I will post some of the finished project.. as far as the cage is concerned... Tom....
        Lookin good man!
          cage....
          Cage is welded... getting painted and installed tommorow.. weather permitting... hopefully I will have pictures of the completed cage tommorow night....
