Quick Question - HO Throttle Body
    Can I use my stock intake elbow and air filter housing with an HO throttle body?
    You should be able to use it.
      yep, outer diameter is the same.
        yes
          Thanks! I might pick up an HO upper and TB for the wagon. Would it help anything on a stock lo-po?
            yes it helps on a stock lopo.....esp if they have duals
              I'm running mine with an HO throttle body and I ported my EGR spacer a bit, Not quite the same bore as the HO throttle body but bigger then stock form, not much noticeable difference if any, although on the interstate it seems to cruise a bit easier.
              Resident diesel addict
