headers?
    headers?
    hey guys, wht kind of headers will fit on my vic? i have a 351w and need it to breath better before i put a new cam in it
    Your best bet is going to be the BBK 351W swap headers for a Fox-body Mustang. That along with a Mustang H-pipe will be a good start for exhaust system. What are you planning for the engine otherwise? That'll help determine what kind of an exhaust system you want to piece together for it.
      im hoping to do alot to it. i originnaly just wanted to cam it. but with the cam i found i need to get a 4 barell carb, intake. im not sure if im gunna go too much farther than that with it. but it only has a single exhaust, and putting a cam in it would be next to useless till i can do the exhaust.
        Better heads are a must too, the stock ones blow. Get E7's or better.
          im kinda on a tight budget too. just out of high school wanting to learn everything about cars
            Remind us again, what year is your car?
              its an 85
                Okay, I'm guessing that will have the E5 heads, then (302s for '85 got E5s, but I'm not sure about Canadian civilian 351s). They actually flow about the same as stock E7s, but the combustion chambers are slightly larger. If you swap stock E7 heads on in place of the E5s, it'll net you a small compression bump, but that's about it. If you're on a tight budget, you might be best off to just leave the stockers in place for now and upgrade later when you have the money to do so.
                  You can use Mustang shorty headers or have some custom made for ya and good luck.
                    BBK shorty headers FTW
                    Addicted to 86-87 Panthers
                      +1
                        about how much would the shorty headers cost?
                          go to ebay... bbk headers
