cc difference question on heads..
    whats the cc's ,86 lo po vs. e7's?
    E6SE = 67-69cc
    E7TE = 62-64cc
      thank you,thank you very much
        interesting ed.......so what do you think compression ratio is on a lopo shortblock with e7 heads?
          Other than saying "A little more than a HO engine", I don't have an exact answer. You would have to know the volume of the reliefs of a HO piston, and the compression height of both pistons if they are not exactly the same.
