Codes..
    Codes..
    Can anyone tell me what this crap means?
    44) Secondary air injection system inoperative - right side (R)
    94) Secondary air injection system inoperative (left side) (R)
    12) cannot control RPM during engine running self-test high RPM check (R)
    31) EVP or PFE circuit below minimum Voltage (O)(R)(C)
    '95 Ford Bronco XL -
    sigpic :rebel:
    Um......The truck or the Vic? What it sounds like to me...If its the vic....AND if you took out the air pump and emissions junk....That the computer is throwing codes at you telling you to fix it...Its funny like that.....This is just a guess..
    I'm I right Scott?
      It's the '90 Vic. I didn't remove anything.
      sigpic :rebel:
        Sounds like an IAC, otherwise I wouldn't worry about the first two...
          egr posistin sensor or a broken vac line on that code 31
          same with the thermactor codes, vac lines prob fuxored
            EGR is stuck/clogged, sensor is bad, IAC clogged....
              Could also be the ports in the back of the heads are clogged. The thermactor crap won't really affect anything.
                I'll have to take the egr and iac off and clean 'em then, see if that works. Then check for vac leaks. Been thinkin' bout throwin it back on the road...I dunno. Truck seemed to be OK in the snow today, I have 250 lbs of sand in the bed.
                sigpic :rebel:
                  44 & 94 are for the smog stuff, from all that I understand they will not adversely affect the engine. Anyone that rips the smog stuff out will have these two codes, I do.
                  1986 Grand Marquis LS 2 Door
