I'm selling my stock 87-93 mustang shorties and the buyer wants to know if they will fit a 1963 falcon 289 with 4 speed manual linkage. Anybody know?
shorty headers on a 289?
they'll bolt up, but not a clue if they're set up the right way to actually be able to hook pipes to.86 Lincoln Town Car (Galactica).
If the engine bay of a '63 falcon is in any shape, form, or fashion similar to that of a '69 'stang they'll fit, but will be extremely tight, and almost hit the firewall
i've seen em on early mustangs.......mustang was designed out of the falcon parts bin iirc
Summit does list these Hedman shorties for Windsor-powered '63-'64 Falcons. At a glance, they do look strikingly similar to the later 5.0 Mustang parts except for the three-bolt flange .... although, the passenger-side exit angle looks pretty funky.
