Thesis
    Thesis
    I have a thesis.
    Could my stalling have actually been caused due to air inside of the brake line? I think of this due to. When i would stall i would be on my brake. And i know the brake booster uses vacuum. Or well anything to do with bad brakes.
    So far i have not come close to stalling. ( although i still haven't been to wal mart yet hehe ).
    Thoughts?
    No. Air in brake lines would in no way cause the car to stall.
      k, And i spoke to soon as well hehe.
        A leaky booster could conceivably do it, though, I would think...
          A leaky booster is a HUGE vac leak.
            I think you mean THEORY. Or possibly hypothesis.
            But either way, no way that'd happen.
              the·sis [thee-sis] 1.a proposition stated or put forward for consideration, esp. one to be discussed and proved or to be maintained against objections: He vigorously defended his thesis on the causes of war.
                Been a long time since i have had to use thesis - Hypothesis - theory.. Theres not many people around to talk about science about... So do forgive me if i got the wrong definition with the wrong word... ( i really thought it was right though )
                Ok. So how can i test the brake booster.. I would think by hearing air sucking in it.. But eh?
                  Your brakes wouldn't have much assist, there would be a large vacuum leak, which you could hear.
                    : nods : mkay. hehe. Back to looking at what Mike and Sue er alice stated about the Map Sensor. I think ima take my car to that "Joe Frank" And pay him to diagnose it.. And ima ask both Mechanic's about a 4bbl convo. With maybe a used carb they might have laying around. I know Joe can rebuild one ive seen his work.
                    But anyways hehe.
                    This reminds me. Any one know how to fix/replace a wiring harness clip that goes to the map sensor?
                      You go to a junkyard and cut off a harness or two that has a good clip, the play with it sliding a narrow knife between metal connectors and the plastic clip till the wires are freed from the clip, then do the same with yer original harness and swap clips over.
                        cool thanks mang
