Originally posted by 86GmLsCoupe
View Post
Push Bar/Brush Guard
Originally posted by Nathan in MN View PostThat's the thing I've been worried about - mounting it to the frame means you lose the shock absorption function of the bumper. You think that'd make an accident more injurious, or would you just mangle the other guy's car more seriously?Last edited by 88MercWagon; 09-02-2007, 05:00 AM.Nick
88 Colony Park LS
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yeah, hard to say what would happen. I'm just not sure if I mount it to the bumper if that'd be as strong. My biggest concern is, if I hit a deer, I WANT TO WIN.
Dear Panthers,
Deer (usually) push the grill into the radiator and/or take out a headlight or two. One of my neighbors has taken out twenty dear and none of them have come over the hood. The panthers are lower than his F 150, but I nailed a big doe in my Pugeot 505 at 50 and she executed the standard flight pattern.
But I wonder if a bumper calmped steel grate - like Melikey's- wouldn't fold back into the radiator. Okay and helpful at low speeds -20-25, but not much use above 35.
The discussion is important to me because I often depart for sheepdog trials at 3 am, there's tons of deer and the last time I rolled off the farm for three weeks in the west, in fog at a low speed (couldn't have been doing 25), I encountered a Senator Craig suicidal deer, and crumpled the front end and dislodged two headlights but none of the radiators.
The obvious solution is a rig like Melikey's but, as (as he noted) a fixed upper brace to the frame would defeat the 5mph bumper impact.
That's a shopping center impact but, I've had my share of those.
Looking at my 89 cp, penetrating the plastic for an upper brace bull bar to frame that didn't look like Chainsaw Jim's work, would be trickey but ...
presuming that problem was solved; why couldn't that brace's attachment to the frame incorporate a pair of old stock absorbers?
Donald McCaig
Dear Panthers,
Deer (usually) push the grill into the radiator and/or take out a headlight or two. One of my neighbors has killed twenty dear and none of them have come over the hood. The panthers are lower than his F 150, but I nailed a big doe in my Pugeot 505 at 50 and she executed the standard flight pattern.
But I wonder if a bumper clamped steel grate - like Melikey's- wouldn't fold back into the radiator. Okay and helpful at low speeds -20-25, but not much use above 35.
Looking at my 89 cp, penetrating the plastic for an upper brace bull bar to frame that didn't look like Chainsaw Jim's work, would be tricky but ...
presuming that problem was solved; why couldn't that brace's attachment to the frame incorporate a pair of bumper absorbers?
Donald McCaig
Originally posted by yucatec View Postpresuming that problem was solved; why couldn't that brace's attachment to the frame incorporate a pair of bumper absorbers?
