cam lift.
    cam lift.
    Whats the most lift i can get on a cam on the stock lo po block and heads. i wanna swap mine out for 351 cam so it sounds better but i dont want to go too big and smack the piston.
    1989 Grand Marquis LS
    most 351 cams are not as aggressive as 302 cams
      Don't go any bigger than a stock HO cam
        the rule of thumb is .500", anything more and you will run into problems.
        Several guys on T-bird/Cougar sites are running the E-cam (.498" lift) with non-HO pistons and havent had any piston/valve contact issues.
        like Mercracer said, the HO cam is your safest bet, you can add 1.7 rocker arms and increase the stock lift from .444" to .474"
