My accelerator is 'heavy' to push.
Found that my throttle cable seems a bit too long - and hence is not quite a straight run between EFI throttle Body and Firewall. It bends in an S shape.
Disconnected at the throttle body end, and from the throttle body bracket - so that the cable was now straight - and throttle pressure from my foot was much less. So I think I am on the right track.
My questions are:
1) It seems like a genuine Ford part (matches picture in workshop manual) - how can it be 'too long'?
2) Anyway to 'shorten? The flat bracket attachment seems crimped onto the outside of the cable. No way to move it I can see. And the very end (throttle end) of the cable is also crimped.
3) Replacing the entire cable seems to be very hard - as there are bolts I can't get to on the firewall sorta behind the vacuum assist for the brakes. Am I missing something?
The 'extra' length I am talking about is about 3". Guess I could move the Engine forward 3"
Rob The Aussie
My questions are:
Rob The Aussie
