Newbie air ride help
    i believe my 01 ls has the air ride as they all came factory right?.. i would like to know since the manual says to turn it off before lifting where is the switch ? if anyone has a picture it would be great !!!
    also from what i understand the sensor is under the car above the axle correct ?
    01 grand marquis ls all stock for now
    I have no pictures but the switch is in the trunk, I believe on the drivers side. It is a fairly large toggle switch, fairly easy to see.
      hmm .. i do have a cutout over there .. only things i can locate on the driver side are a red button on top. "assume thats fuel shutoff" and a pull cable for the fuel door below that there is a cutout but nothing there
        Not all of them had air suspension. If you look in past the rear wheel you should be able to see either a coil spring or the air spring.
          I missed the basic question. DOH! Did they have air ride without dual exhaust?
            idc if it has it or not .. just if it did have it i wanted to be aware lol .. ill have to check under it and see just havnt had time and was to exited when i bought it to check lmao..
            it does have factory dual exhaust though less $$$ i got to spend although i am swapping out the mufflers for some magnaflows
              Not sure on the 01's but on a '95 GM the Air Suspension switch is on the Passenger side of the trunk.
                Get stainless mufflers to go with your stainless pipes. I am not 100% sure but usually duals were in a package with air suspension except for taxi and cop models. It is possible that the bags went and somebody went cheap and put in coils.
                Jay
                  On the 98+ the air ride switch is black with white lettering on the drivers side in the trunk, right behind the right inertia switch. If the air ride switch isn't there, then you do not have air ride.
                  You can also look under the hood near the air box for the pump.
                  08 Lincoln Navigator L - 233k
                  03 Mercury Marauder- 63k
                    no switch no pump .. to cold to get on the ground and look i cant see anything through the wheel well im guessing she doesn't have air ride
                      Correct, you probably don't have it.
