1996 Marquis Coolant leak
    High 318XXX mileage engine all original.
    Just did the water pump, t-stat, reservoir tank, fan clutch, idler, serpentine, and a couple other misc parts....
    I looked today to just to do preventative maintenance and found were the tstat housing meets the intake it has begun to weep, I didn't even notice it on the reservoir tank
    The leak is more of a dribble than a full on leak....
    I did notice that when replacing the tstat that one of the silver washers that go on the housing were missing...NOW could this be the issue, It wasn't leaking before though...
    If you need picks let me know.
    Thank you,
    P.S. This car has done allot more for me, so I want to do something for it.
    Thanks again
    Pics would help for someone like me who doesn't know the year-to-year variations very well. They would also help if non-stock parts were being used.
    If yours is the o-ring type, I'd be guessing the o-ring wasn't seated properly. If the silver washer you're talking about is one of the spacers for a housing that has big bolt holes, not having that could result in the housing not being aligned properly and not being properly seated on the o-ring. If you mean the washer that's under the bolt head, I wouldn't think that would make a huge difference, but I could be wrong.
      I will go get picks asap, Im working three about to start 4 jobs now so my time management is kinda bad...
        Pics[ATTACH=CONFIG]42769[/ATTACH][ATTACH=CONFIG]42770[/ATTACH][ATTACH=CONFIG]42771[/ATTACH][ATTACH=CONFIG]42772[/ATTACH][ATTACH=CONFIG]42773[/ATTACH][ATTACH=CONFIG]42774[/ATTACH]
          probably just needs a new o-ring for the thermostat. Torque spec on those bolts should be 15-17 ft-lbs The o-ring is not the same as the rubber ring supplied with a new thermostat just so you know.
            You pointed at it with the wrong finger
              Its seems to have stopped or just started to trickle...BUT what do you mean by that above sentence...? The O ring?
                These don't use a gasket to seal the thermostat housing, but a large o-ring. The thermostat drops in and then the o-ring on top. If the seal that comes with the thermostats was used it will leak because they are made to fit around the thermostat and not on top of it like this setup.
