Torque Specs 4.6L {Engine}
    Found these on the internet at one of the many Mustang places, and thought it would be usefull for us as well. Keep in mind they are for the mustang engines.
    4.6L Torque Specs
    Camshafts caps to head 71-106 in/lbs
    Camshaft sprocket bolts 82-92 ft/lbs
    Cylinder head bolts SOHC (two valve GT and Bullitt)
    --Step 1 28-31ft/lbs
    --Step 2 Tighten additional 90 degrees
    --Step 3 Loosen one full turn
    --Step 4 28-31ft/lbs
    --Step 5 Tighten additional 90 degrees
    --Step 6 Tighten additional 90 degrees
    Cylinder head bolts DOHC (four valve Cobra, and Mach One)
    --Step 3 Tighten additional 90 degrees
    Drive belt idler and tensioner bolts 15-22 ft/lbs
    Engine compartment brace bolts 15-22 ft/lbs
    Engine mount to engine block bolts/studs 25-33 ft/lbs
    Engine mount stud to crossmember nuts 95-126 ft/lbs
    Exhaust manifold to cylinder head bolts 14-16 ft/lbs
    Flywheel moutning bolts 59-64 ft/lbs
    Ignition coil brackets to front cover 12-22 ft/lbs
    Intake and side plates assembly to cylinder head
    --Step 1 15-22 ft/lbs
    Intake manifold to cylinder head bolts
    SOHC (two valve GT and bullitt) 15-22 ft/lbs
    DOHC (four valve Cobra and Mach One)
    Upper plenum to intake 71-106 in/lbs
    Intake to lower side plates 71-106 in/lbs
    --Step 1 15 ft/lbs
    Oil cooler to filter adapter insert
    -1996 59-74 ft/lbs
    -1997-later 41-53 ft/lbs
    Oil filter adapter bolts 15-22 ft/lbs
    Oil pan to engine block bolts
    -1996 15-22 ft/lbs
    -1997-later
    --Step 1 15 ft/lbs
    --Step 2 Tighten additional 60 degrees
    Oil pick up tube to main bearing cap nut 15-22 ft/lbs
    Oil pick up tube to oil pump bolts 71-106 in/lbs
    Oil pump to engine block mounting bolts 71-106 in/lbs
    Thermostat housing bolts 15-22 ft/lbs
    Timing chain cover bolts 15-22 ft/lbs
    Timing chain tensioners and guides 15-22 ft/lbs
    Valve cover bolts 71-106 in/lbs
    Vibration dampner to crankshaft bolt
    -1996 114-121 ft/lbs
    -1997-later
    --Step 1 66 ft/lbs
    --Step 2 Loosen one full turn
    --Step 3 36 ft/lbs
    --Step 4 Tighten additional 90 degrees
    Water pump mounting bolts 15-22 ft/lbs
    Water pump pulley mounting bolts 15-22 ft/lbs
    Wheel lug nuts 85-105 ft/lbs
    Head pattern
