So I finally got pics of the destruction in my old Tranny. It was as I throught, the planetary gears were trashed. Broke a few teeth off, most all of the teeth ridges are trashed, one of the thrust bearings got trashed, 2 of the planet gear's shafts came lose in the gear housing. You can see the heat disscoleration on in the pics, along with the obious amount of play. In the last pic you can even see where it had broken the housing. This thing was holding the whole time, it drove over 2 weeks (about 600miles) with grinding noises. I have to give it up to that sucker, it withstood a beating and kept on ticking. Keep in mind I knew it was trashed, so I didn't go easy on it for those two weeks, and it still held!
:worship: AOD
:worship: AOD
