is the 5.0 distributor compatiable with the 5.8?
{ENGINE}distributor question
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
thats what i thought. i was looking up distributors and a replacement from Auto Zone and it is $100 +core for a replacement and i can get a MSD for like $230http://secondhandracing.com/Home.aspx
yea but it i also have a Crane fireball HI-6s ignition that piggybacks with it
i found a couple of different billet distributors for a little over $200 so i might go that routehttp://secondhandracing.com/Home.aspx
make sure you get the dist for the 351w.......not the 351c
a few years ago i replaced the dist on my 73 cougar it had a 351cleveland........some bozo sold me one for a windsor..........it worked for a day and then it ripped the teeth right off the camshaft........bastards!
scott
Originally posted by EvilCrownVicOriginally posted by lincolnmaniamake sure you get the dist for the 351w.......not the 351c
scott
scott
