fuel pressure question
    i need a universal electric fuel pump and i dont know how much p.s.i. ,c.f.h. and or c.f.m. that i need.
    i found this one on ebay . will it work for my 84 gm
    If you are converting to a carb, yeah...
    The same one sells for 31 bucks at advance...
      no carb. im still using TBI
        Then no. lol
          what do you think i would need .
            is it a big ordeal to change it to a carb
              i don't have a lot of money. i cant use the original pump due to the mustang tank swap. and the old stangs used a mechanicel pump on the block. which i cant use...
                will this work
                  Why can't you just modify the stock pump? Bosch makes nice frame mount pumps that people use universally..
                  If the stock pump is too large of a diameter, just geta stock 87-93 mustang fuel pump. It's smaller diameter and would fit in the tank a bit more easily. Just make sure to use some high pressure fuel hose. You should need a pump that can do about 60-70psi and flow over 80lph or so.
                    im not using the stock tank. i have a 1964 mustang tank
                      I am aware of that. Why can't you modify it for an in tank?
                        I dunno. What would i have to do? I don't know much about this kinda thing. I"m certified in auto body not mechanics..
                          Not sure, I'm not too familiar with the old tank, but I think it wouldn't be too difficult. I'd just take out the part that has the pickup and put the fuel pump on it. Prolly a lot easier said than done though.
                            cool idea.. Ill take apart the old tank tomarrow and see what i can figure out
                              Holly shit, :banana: You are the man. :slug: The stock pump looks identical to the aftermarket one. and i can use it externaly :headbang:
                              Thanks for the info... :rock:
