Wow, I just changed the vc gaskets on the 91 colony park yesterday. It was surprisingly difficult and took 4 hours. Is there anyone who might know the trick to doing this quicker? specifically, the drivers side top rear bolt on the cover (over the #8 cyl) seemed really difficult to access. I used an 11mm craftsman deepwell with a 3/8 drive after attempting several different u-joint-extension combos. I ended up unbolting the upper plenum and disconnecting the throttle and cruise linkages to get more access to both sides. Just fishing for tips if anyones got any.
{ENGINE} valve cover gaskets.
1991 GM GS sedan "Love Boat" HO converted, Holley adjustable fpr, 3.27 Trac-lok - RIP
1991 Colony Park LS "Wally World Express" HO, 3.27 trac-lok - RIP
1988 grand marquis ls "grey ghoul" - RIP 1992 gm ls "superbeater"- sold 1993 F350 dually 7.3 IDI crew cab flatbed "killer" - RIP
1994.5 F350 Dually Crew Cab Flatbed, Powerstroke 7.3 "overkill" - Alive and kicking
1987 Lincoln Town Car "El Presidente" - Resting for winter, gonna be a beast!
2008 Mustang, no name - belongs to the wifeyTags: None
you can get the drivers side valve cover off without removing the upper plenum........the pass side is a no go......gotta remove the upper plenum
scott
:stupid:
Luckily the upper plenum is pretty easy to pull, and it does make changing that PCV valve a lot easier. Actually thats how I found mine, when I did the vc and intake gaskets on my old motor.86 Lincoln Town Car (Galactica).
