{ENGINE} valve cover gaskets.
    Wow, I just changed the vc gaskets on the 91 colony park yesterday. It was surprisingly difficult and took 4 hours. Is there anyone who might know the trick to doing this quicker? specifically, the drivers side top rear bolt on the cover (over the #8 cyl) seemed really difficult to access. I used an 11mm craftsman deepwell with a 3/8 drive after attempting several different u-joint-extension combos. I ended up unbolting the upper plenum and disconnecting the throttle and cruise linkages to get more access to both sides. Just fishing for tips if anyones got any.
    1991 GM GS sedan "Love Boat" HO converted, Holley adjustable fpr, 3.27 Trac-lok - RIP
    1991 Colony Park LS "Wally World Express" HO, 3.27 trac-lok - RIP
    1988 grand marquis ls "grey ghoul" - RIP 1992 gm ls "superbeater"- sold 1993 F350 dually 7.3 IDI crew cab flatbed "killer" - RIP
    1994.5 F350 Dually Crew Cab Flatbed, Powerstroke 7.3 "overkill" - Alive and kicking
    1987 Lincoln Town Car "El Presidente" - Resting for winter, gonna be a beast!
    2008 Mustang, no name - belongs to the wifey
    Unfortunately, you gotta remove the upper plenum to get to the V/Cs on an EFI car
    You should prob replace the PCV sreen while ur in there...
      you can get the drivers side valve cover off without removing the upper plenum........the pass side is a no go......gotta remove the upper plenum
      scott
        :stupid:
        Luckily the upper plenum is pretty easy to pull, and it does make changing that PCV valve a lot easier. Actually thats how I found mine, when I did the vc and intake gaskets on my old motor.
