In an effort to reduce the number of stickies I am creating this thread.
This thread will contain links to various technical articles and other random important information.
Ford OBD-II DTC
More Ford Codes
Upper Ball Joint
Oil Filter Adapter
Rear Axle Oil Change
How to clean the MAF
Some Suspension Stuff
Ford Rear Axle Lube Info
Ford RWD Transmission Ratios
Air Filter Study
Headlamp Adjustment
Engine Miss
Idle Problems
Heater-AC Blower Speed Problems
Engine Schematic Diagrams
EGR Tech Article
Intake Swap
PI Intake Swap
"J-Mod" Valvebody Mod
This video may be helpful for those who want a first hand look at most of the procedure. The use of the lower 2-3 spring in the lower 1-2 spot is AT YOUR OWN RISK. The use of an Impact Wrench to remove the VB bolts seems bullish to me.
If you are still have not found the answer to you question...
Post it or PM seneeb
I have also started to upload exploded views of certain key things and other random tech stuff from a Ford service CD. They can be seen here.
Linky...
Where to get performance parts:
ADTR Your Panther Performance Specialists.
Innovative Interceptors Tell Wes I sent ya.
Team Ford Parts Most discounts are 25% off Ford MSRP
I hope this helps.
Ford OBD-II DTC
More Ford Codes
Upper Ball Joint
Oil Filter Adapter
Air Filter Study
Headlamp Adjustment
Engine Miss
Idle Problems
EGR Tech Article
Intake Swap
PI Intake Swap
Linky...
I hope this helps.
