re-did my drum brakes thanks to the groundhog and the old man - heres some info!
return spring tool - press this over the post and twist to remove the spring
hold down spring tool - again push and twist
misc spring tool - slip the end over the spring arm, twist in to lock the tool onto the spring. much easier than using side cutters or pliers!!!
my wheel cylinder came out with a 1/2" on the bolts, and a 7/16" line wrench on the line.
lube!
also lube the threads and cap on the star adjuster
tada!
drum brakes require patience - many parts to remeber where they go, and as you re-assemble, the shoes like to shift around on you while you set the springs, and can cuase other parts to fall out of place and raise your blood pressure.
adjust them up - more info on this here
lube!
tada!
