This has probably been asked before, but what is a cheap way of converting the rear drum brakes to discs? Would using a 92+ rear axle work, or is it more complicated and expensive? This is just a thought and I might not even attempt this, but if I'm really bored I can do amazing things.
Rear Disc Brakes
it's easy and inexpensive..........u need backing plates, calipers, hoses, parking brake cables and rotors/pads from a 92-97 car
