I made a few step by step instructions for removing a carrier from an 8.8. I took the pics when I was doing my rear end build up. So install was a little different for me, and is a whole nother topic to itself. If there is anything you all can think of to add feel free.
After the final step, it should be noted that the carrier should have a pre load and should take a little tugging to get out, however CAUTION!!!! It may not, and could fall out, hurting the carrier is not what I am worried about, it's a pretty heavy chucko' metal...so just take a little caution there.
