a couple of pointers... use only ATF in a Ford PS system. Type F is the best, but dextron will work. DO NOT use regular, clear type PS fuild.
Well sh!t. I've been very careful to use PS fluid. I've used a hell of a lot of it too, 'cuz I've replaced the pitman shaft seal 3x and it still leaks. Maybe with the right fluid it won't.
i've always used ps fluid.......never a problem.......should i change?
I just flushed my PS yesterday, and I also upgraded it with the police tranny cooler I had laying around - it's finally hooked up, downstream of the gearbox. Filled up with Mobil 1 full synthetic ATF, went with the Dextron type as I already use it in my tranny and I don't like having 5 quarts of different chemicals jumping around in my trunk. There was no moaning before, there si none now either, but I did notice that the steering hose between the gearbox and the cooler doesn't get as hot as the original return line - is that something that can be attributed to the ATF?
This is regarding the PS leak on the '88. Been getting pretty bad lately. There's such a big friggin' mess down there that I can't tell where it's comin' from.
The pump has been wining pretty bad and the fluid is where it should be. I'm tempted to just pull the pump, lines, and gearbox to either: clean them up and try to find the leak or just replace the whole works. CarQuest has the pump w/ reservoir for $49 and the gearbox for $150. I'm getting tired of seeing that big damn mess under the hood and on my garage floor.
How does the gear box detach from the steering shaft? Any tips on removal? I haven't gotten down there to look at it today, short on time.
If the seal on the gear box is leaking, can the seal be replaced or would it be cheaper/easier to just replace the whole thing? All info is appreciated.
Before you do anything, liberally apply degreaser and pressure wash the engine bay to get rid of the goop, then have a look underneath to determine where its coming from after driving home in your nicely cleaned car.
I've heard that its hard to replace that seal and get it to actually seal. Not sure on yours, but I'm fairly sure you just have a single clamp bolt below the rag joint that comes out, then the steering box slides off the shaft. 3 bolts hold it to the frame. The hardest part is getting the pressure line to break loose really. If the clamp bolt on the box doesn't let go, half the steering shaft will slide apart, so its not that big of a deal. It should seperate between the rag joint and that other joint up next to the firewall.
The seals are a pita to replace. I did the input seal on mine with the box in the car. Now the output seal is leaking. I'd upgrade the box to a newer if that's what's leaking...
I yanked out the ps pump tonight. What a fuckin' mess down there. From what I can tell, the leak is from the pump or one of the rubber lines. The gear box didn't appear to have anything for fresh oil on it to indicate leaking. I'm ordering my new pump Monday. It was a bit of a bitch to get the bracket out. Since everything was out, I went ahead and rethreaded my oil-sending unit. It wasn't as tight as it was supposed to be.
The rubber line that comes out of the back of the ps pump wraps down and underneath the pump and connects to the metal line. I can't seem to seperate the rubber hose from the metal line. I even pulled the clamp off. Do I have to replace the metal portion of the line as well as the rubber peice, or should that rubber line come off?
yes, the metal pipe and rubber hose seperate. use a razor blade and cut the hose off the metal line. use transmission fluid rated 3/8" rubber hose as a replacement. re-use the metal line. some new clamps are a good idea too.
2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011 89 Crown Victoria LX HPP -- SOLD 9/2010 88 Grand Marquis LS - The Original -- Totaled 5/2006
just replace both lines, since you have the pump already off.
the High pressure line is like $20 at Napa.
Got the new pump today. Didn't have a pulley puller, so I ran down to my mechanic. He was nice enough to pull and install the pulley for no charge (I do a lot of business with them). Also picked up a new low pressure hose, ps fluid, Lucas ps fluid treatment, and clamps. I'm taking tomorrow off to install everything. Seems to be the only nice weather day for a while and I need a break from work.
New pump is in and running quiet. I still think the gearbox may have a leak, but it doesn't seem to be bad. I've got an antifreeze leak and an oil leak, but I can't pin point 'em. I suppose leaks should be expected at 170K miles.
