the 05 rear end uses a 3-link set up it will not work unless you have some fabricating skills and can make brackets and weld them, on top of that the rear is probalby about 3" to narrow.
{DRIVETRAIN}Rear end build up! NEED TO KNOW?
Yeah I know there is gonna be a lot of fabrication to get it to fit, but if I can get it to work for free that'd be awesome. The width thing is the only one I'm stuck on. When I go home this weekend I'll see how long it is and if it will work or not. That is pretty much the determining factor. The brackets I can cut off my original and weld on to the new, hopefully. But if it's too short I can't do much with it, however if it’s too wide (I doubt it) I might still be able to do something. The Muastang is thinner than our Vics an GMs, but all new cars have a larger backspacing too.
We'll see this weekend if it will work or not.
if you but to much negative offset you can load your bearings in a bad way causing the bearings to wear out wear out very fast.
also im putting 15x10s in the rear, that will fit up to a 325 tire.http://secondhandracing.com/Home.aspx
Also not sure if the rear discs from a 'stang rear woudl work properly with the E brake cables from a box. You coudl strip the gears out if nothing else, assuming its an 8.8" rear.86 Lincoln Town Car (Galactica).
when the mounting flange of the wheel is inboard of the centerline of the wheel it has negative offsethttp://secondhandracing.com/Home.aspx
Blaze!
welcome :slug:Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
