Dear Wagoneers, Mr. Gadget asked?"Are the pins replaceable like the door hinges are? If so, I think you can just cut the old pins out and drive new ones in."
Think of a hinge with a brass bushing which has worn through and the retaining circle is also worn to wobbling. No good to just replace the bushing. Might weld, drill, replace the hinges and will if I can't find a sound used set (no longer available from Ford). Problem here in Virginia is that most of the 89 anythings have been crushed.
Donald McCaig
1989 CP Scottified steering, suspension and big brakes, 16 in wheels, A-pillar oil & temp gauges, remote entry, backup sensor, tailgate wiper, custom console & trash, tranny & ps coolers, 3 cell radiator, electric fan, dual exhausts, battery isolator, hellas headlights,deer pusher,wads of dog hair.
