tailgate window motor
    anybody know how to get the 'gate motor out?
    thanks.....
    I haven't done the tailgate in a few years, but if you find the location of the motor behind the door panel, you should see three dips in the metal. Drill those out with a 1/2" drill bit and you can access the bolts holding it in. I want to say they were 7/32 or something ungodly small.
    Hope that helps.
      no dimples... that's what i expected to find after doing side doors....
      i guess i could just get out the sawzall LOL
        The guy my dad paid to replace my tailgate window motor used a sawzall and it looks like shit. Please don't do that.
          I was kidding.....but I still need to figure it out.....
            i did somany of those i should make a tech artical! its very hard to explain, i would habe to give mesurments to drill hols for screw access., i will try to get mesurements the next time i see my old mans wagon, but i can tell you this, u need a drill bit bigger than a 5/16 1/4 drive socket!
              Bump. :hacksaw:
                Sounds like it's like every other door. 9/16" drill bit and a 5/16" 1/4" drive socket.
                  I did both of my rear windows AND the tailgate window on my '88 Colony Park today.
                  The tailgate is much more difficult than the doors, because of the smallish access holes, and NO DIMPLES.
                  My best advice is to first remove a DOOR panel, and look at the locations of the 3 bolts that hold the motor in place.
                  The tailgate is similar.
                  Look closely, and you can just see the upper left (as you face the inside of the tailgate) bolt. Drill a 1/2" hole in the panel so you can remove it.
                  All the holes you drill are below the trim panel, so they will not be hidden when you're through like on the doors. Try to be accurate when you drill!
                  Feel around, and you can just barely put a finger on the upper right bolt.
                  Drill another 1/2" hole and remove it.
                  The third hole is almost at the bottom edge of the tailgate, a little left (your left, not the cars left) of midway between the two previous holes. Good luck on this one!
                  The motor and repairs are the same as for the doors.
                  Cover the holes you just drilled with duct tape and/or sheet metal when you finish, to keep dirt and exhaust out of the car. You can find matching color duct tape at some hardware stores...
                    Yeah, old post, I know....
                    Is this doable with the regulator still in the tailgate? Can I simply pull out the motor, once the screws are loose and swap in a new motor? I remember exchanging a window motor on a 82 Corvette and having a hard time snapping the motor in on the bench in a vice, working against the pressure from the regulator spring.
                    Regards, Alex
                      No pressure from the regulator spring. Not sure if it’s just not there or the design holds the spring in place during replacement but nothing to worry about.
