Wagon peeps! I have an odd problem. The tailgate wont go up or down with the key. That's not what's odd about it. I removed the switch and it's working fine. The problem is there is nothing to actuate the switch, and even if there were there are two metal tabs surrounding it that make it so the switch cant be pressed far enough to allow it to work. It simply just rotates with the whole assembly as the key turns.
Is it mounted incorrectly? Am i missing a piece? What going on here???
